need rising rate FPR??
Just wondering if i would need to run a rising rate fuel pressure regulator on a vj11 set up on a DOHC B6 at around 7-8 psi??? Or would a adjustable fuel pressure regulator be good enough with bigger injectors??
- XxantwawnxX
I think FMU would be better..so you can run nice on boost..and not be rich as crap on idle. so yeah a rrfpr or fmu.
- babyblueMX3
- XxantwawnxX
Yea when i said rrfpr or fmu...i did not mean one or the other...i meant there the same. Guess i could of worded it better.
- XxantwawnxX
No an FMU is the same thing as a rrfpr (rsing rate fpr) which is just installed in series of your stock fpr. It uses boost pressure to raise the fuel pressure accordingly. For low boost operations i hear these work fine , im using one for my 4-6 psi boost configureration.
Where would i find one and how much are they?? Dfoes it replace the fuel pressure regulator, or do i still use my adjastable fuel pressure regulator??
- XxantwawnxX
You can find them all over ebay. I think vortec has some..and cartech. Usually i see prices from 100-300.
- XxantwawnxX
If im not mistaken, your adjustable FPR replaces your stock FPR right? If so then yes you can still use it. Just put the FMU in series with the adj FPR.
This is what you want: RRFPR is different from FMU.
http://www.bellengineering.net/Pages/products_FPR.html
Turbo 94 Protege LX
- babyblueMX3
huh ? where do you come from..the link you posted is for BEGI fmu ..the same one I used to run withrukick wrote:This is what you want: RRFPR is different from FMU.
rrfpr = fmu !!
scroll down your page, click on :
Click here for the 2020 Series FMU
then tell me what are the first words on the other page.:
yeah that's what I thought.
Before telling somebody they're wrong, get your facts straight first
No offense
http://www.racetep.com/begireg.html
RIP 400whp ZE-T MX-3
