supercharger mx3?
deathman
supercharger mx3?
Post by deathman »
i have a mx3 92 v-6 2.5 kl.
when it was in my probe i supercharged it, put were the a/c sets.
i looked at my mx3 there is no as much room as the probe.
i was wondering if anyone has done it here on a mx3?
if so any problems they ran into, other than your make everthing lol
here is my car site:
http://www.cardomain.com/ride/1301296/1
jschrauwen
Re: supercharger mx3?
Post by jschrauwen »
deathman wrote:i have a mx3 92 v-6 2.5 kl.
Adlorin is supposed to have a kit available for the MX3 this spring.
http://mrspeed.biz/klsckit-install.aspx
deathman
Post by deathman »
i already have a kit, just wondering if there is any mx3 problems that the probe doesn't have, mainly clearance problem's
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
jschrauwen
deathman wrote:i already have a kit, just wondering if there is any mx3 problems that the probe doesn't have, mainly clearance problem's
From what I've read so far from Adlorins info - NO. Since we don't have the obstacle of the headlight, the SC will reside abeam the disty almost in the same location where the oem airbox is. A long pully driven intermediate shaft will run the length of the engine just in front of the front valve cover. At the end of the intermediate shaft will be another pully with a short belt going to the SC pully. Intake air will be drawn from the rear of the SC through intake tubing and filter that will run into the fender well. The forced air will run to the TB which is only about a 12" run if intake tubing. I've seen a similar set-up already on a probe in toronto. I believe that in the probes case the disty had to be modified because of the limited space abeam the disty. That's not the case with the MX. I hope that's what you were looking for John.
*John*
deathman
Post by deathman »
i would not put it there i was thinking of putting it were the a/c sets
babyblueMX3
Post by babyblueMX3 »
I only seen 2 mx-3 supercharged as of today.
Jeff Abrams old mx-3 (wich he converted to turbo)
had the S/C mounted where the disty is.
and the other guy that is S/C is this one witch I kit will be similar to aldorin's kit:
* edit we posted at the same time. I just saw that you wouldn't want it there.
btw are you a member on PT?
RIP 400whp ZE-T MX-3
MX3ze@7psi
Post by MX3ze@7psi »
It won't clear. I tried it on my mx3. Thats why i went the turbo route. I still have the brackets here and maybe one day I'll try to find a probe and try it on. the supercharger comes way to close to the front frame. You have about 1.5 inch left before it hits the front frame. I used the stock a/c bracket and 1/2 thick aluminum for the bracket. Yours might have alittle more room because I don't see you using the a/c bracket.
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
jschrauwen
babyblueMX3 wrote:I only seen 2 mx-3 supercharged as of today.
Very nice set-up - nice and clean. Not familiar with that SC. Looks a bit bulkier than the Eaton M62 but is configured the same way as my M62 will be, more or less. Nice find Steve!!
babyblueMX3 wrote: btw are you a member on PT?
Yes he is .... same name on there too.
babyblueMX3
Very nice set-up - nice and clean. Not familiar with that SC. Looks a bit bulkier than the Eaton M62 but is configured the same way as my M62 will be, more or less. Nice find Steve!![/color]
that's the picture I wanted to send you months ago but forgot :oops: remember ?
deathman
Post by deathman »
i am a member of probetalk, we were just talken about the 400hp mx3. i think that it's exstream hp for a small car, but if he did that many passes with it i guess he can handle it. you just don't hear of many people making that much power.
the whole project might go on hold because i might be going to kuait in a 2-3 month.
but tell the owner of that mx3 i will take 1 also, and i will give him a wappin $50.00 :D :lol: lol
Return to “Forced Induction”
