what kind of amp do i need?
Posted: November 11th, 2005, 11:34 pm
by 95 rs
so yah im not really familiar with the subs and all so i need your advice.
i got a mtx thunder9500 15" sub and the power on it is 1000w rms i got it for $500 and well they usually sell for 700-800 around here and i got a fiberglass box and all i need is an amp so i need to know what kind should i get to handle that kind of power? any help would be great thanks.
Posted: November 12th, 2005, 12:01 am
by MX-SLICK
at least an amp with 500 watts RMS. Look an Class D mono amps.
JL 500/1 or 1000/1
Orion 600D or 1200D
rockford T1000BD
MTX MXA6001/8001
JBL GTO1201.1
JBL GTO601.1
JBL BPX500.1
Just to name a few. I would get an amp between 500 and 1000 rms give/take. The sub is DVC so you have to cinsider how its gonna be wired (2 ohm, 4 ohm, 1 ohm etc) in contrast to what your amp can handle (some amps can be ran lower than 4 ohms for example)
Posted: November 15th, 2005, 2:37 pm
by Legato626
I got a crossfire 15in BMF that takes 1200watts i am sticking a crossfire VR1000d witch sounds REALY GOOD!!
Posted: November 15th, 2005, 4:42 pm
by Brycek
The ed nine.1 is supposed to be very good. it's rated at 1200 wrms at 1ohm and can be had pretty cheap. What voice coil setup do you have?
Posted: November 15th, 2005, 8:10 pm
by Typhoonk
definetly want to go overboard with this sub!!!! check it out!!! sweet a***!!!
http://www.mtx.com/caraudio/products/su ... er9500.cfm
ur gonna need some 2 gauge power wire, really good grounding system
I'm getting excited just writing this!!!
if the sub is the dual voice coil sub - get something that will hit 500watts at 4ohms and 1000 watts at 2ohms
if it's a single coil sub - then get something with 500-800 at 4ohms adn 1200 at 2ohms
suggest this amp -> MTX amp 81001
http://www.mtx.com/caraudio/products/am ... r81001.cfm
here's a matching page that MTX has for the sub
http://www.mtx.com/Flash2/amps_subs8.html
enjoy the info
definetely get that baby photographed next to an mx-3!! that's a sweet look subwoofer!!! :D :D
wanted to add that u would need 8 gauge speaker wire for this sub to hit it's potential!!!! CRAZY!!!!!
Posted: November 20th, 2005, 7:50 pm
by 95 rs
thanks ill definately get pics of it when i get it installed that wont be until spring tho. it gets way too cold here and i dont want to ruin it during the winter. and yah its an amzing sub. i got an awesome deal on it. i couldnt resist and yah thanks again guys.
