Help with codes
Help with codes
i was doing the timing and I had a engine problem so i connected the data link connector terminals TEN and GND with a jumper wire and got the codes but is there so where I can find out what they mean I called mazda and they were no help they asked me how I did it
Re: Help with codes
What codes did you get?<P>There is a full listing of the codes in the online shop manual. Section F2 I believe.<P>------------------<BR><B><I>David Coleman</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><A HREF="http://www.highlandsun.com/hyc/sae920677/" TARGET=_blank><I>V6 engine info</I></A> | <A HREF="http://www.bradbury.cwc.net/probemx/index.htm" TARGET=_blank>KL FAQ</A> | <I><A HREF="http://www.brownsword.ca/Probe.html" TARGET=_blank>ECU reprogramming</A></I> | <A HREF="http://members.home.net/tekguy/" TARGET=_blank>K series Image cache</A> | <I><A HREF="http://archive.probetalk.com/cgi-bin/se ... tion=intro" TARGET=_blank>Probetalk Archive Search</A></I></B><BR><B>Support OPEC: Buy an SUV</B>
David Coleman
Re: Help with codes
Hey leave it to Mazda to not wanna help out.<BR> im going to assume that you know how to read the codes and convert the flases into numbers. So why dont you go ahead and post or E-mail me the numbers and I will reply with the diagnoses for you.
