Loud Engine at Highway Speeds
Posted: November 7th, 2005, 1:16 am
by Edwood
I have a 1993 MX-3 1.6L manual transmission with 105K miles.
The engine is very loud at highway speeds, and gets louder the faster I go. Particulary starting at around 50MPH. It's a very loud "RRRRRRRRRRRRRR" kind of constant droning noise from the engine.
Are there some bearings worn, or something else in my transmission perhaps? Valves?
It's loud enough that I often wear earplugs when driving on the highway.
Thanks,
-Ed
Posted: November 7th, 2005, 1:51 am
by ryanlindenberg
check out the exhaust...mine had a hole right after the header but it was under a heat shield so it was really hard to see.
Posted: November 7th, 2005, 6:35 pm
by StylinMike
Is it revving really high? Or just loud in general?
Re: Loud Engine at Highway Speeds
Posted: November 8th, 2005, 12:21 am
by cdngrl420
Edwood wrote:I have a 1993 MX-3 1.4L manual transmission with 105K miles.
Thanks,
-Ed
err not tryin to be a-- but you your engine is a 1.6 not a 1.4
Posted: November 8th, 2005, 4:29 am
by Edwood
ryanlindenberg wrote:check out the exhaust...mine had a hole right after the header but it was under a heat shield so it was really hard to see.
It's not the exhaust, I've had that problem before and it sounded completely different.
-Ed
Posted: November 8th, 2005, 4:30 am
by Edwood
StylinMike wrote:Is it revving really high? Or just loud in general?
Revs seem to be normal. It's just loud in general, but it starts to get really loud at about 50-60MPH.
-Ed
Posted: November 8th, 2005, 4:31 am
by Edwood
OK, fixed the error in my post. Now I can get even more helpful posts since people will know precisely the displacement of my MX-3's engine.
-Ed
Posted: November 8th, 2005, 7:07 am
by ariesdude
Is it noisy only at that speed - or is it also noisy when your just parked and revving the engine. If yes then at what rpm does the noise start and gets louder? If its not a rattling noise then maybe it is the exhaust. If its noisy only at specific speed (whatever the rpm is) maybe something wrong with the tires, axles etc.
Posted: November 9th, 2005, 2:18 pm
by Edwood
ariesdude wrote:Is it noisy only at that speed - or is it also noisy when your just parked and revving the engine. If yes then at what rpm does the noise start and gets louder? If its not a rattling noise then maybe it is the exhaust. If its noisy only at specific speed (whatever the rpm is) maybe something wrong with the tires, axles etc.
Well, the engine is noisier than I remember it being when it was new, but not very noisy. Nothing rattling really.
It's at higher highway speeds that it is much noisier. It get's most noisy starting at around 50MPH, but it is not suddenly noisy from nowhere. It ramps up. But it gets progressively noisier, the faster I go.
-Ed
Posted: November 9th, 2005, 11:00 pm
by Edwood
Had my MX-3 looked at. It has bad bearings in the front. and yet another torn CV boot.
Hopefully those are what is causing all of the noise.
-Ed
