greddy profec b (not spec 2)
- facko
hey can anyone gimme a run down on how this thing works. i bought it from a guy and he didnt have the instructions so im just wondering what everything is for...and how much boost each notch represents....i got it installed already just needa know wha tim doing when i start playin around with it
BP swap -- Pacesetter Header -- Custom CAI -- Custom 2.5 Exhaust w/ a Thrush Glasspack and 40 Series Flowmaster -- SPEC Stage 2 Clutch Kit
- BuGS
oh you don't want that one. You need the spec 2, you should just give me that
No, There is a low boost and high boost if I remember then the other nob is for how fast the Actuator will open. If you set it to the low setting your turbo won't spool as quick cause it opens the wastegate parshally. For a quicker spool set it the other way....
- facko
lol i think ill keep this one its pretty nice
and i only paid 100 bucks for it
but thx for the info, i wasnt sure what the other nob was for so i just left it alone in fear of puttin it on some setting my car couldnt handle
had a profec b
great BUT
you need to change boost levels in gear!
strange but the controller will allow changes only while moving ( in gear)
strange but it does work well. i recommend using it w/ the high and low boost and keep in mind when the unit is OFF it will work at the wastegates' spring rate.... giving you 3 settings actually.
i have a spec2 now and no experience w/ it yet
great BUT
Garage (sort of)
99 Acura Integra GSR-T (totaled)
03 Mercedes Benz C230K (rear upgrade from 3.27 to 3.67 ratio) running strong at 108K miles
92 MX-3 v6 (that i wanted to twin turbo w/ an ht12 and ht15) - Parting out now!!!
90 MX-5 getting the rotary treatment
bdavis2005 @ gmail . com
feedback link -> http://www.mx-3.com/phpBB3/viewtopic.php?f=37&t=62911" onclick="window.open(this.href);return false;
"GReddy PRofec B
The GReddy PRofec B-spec. is one of the simplest, easy to use electronic boost controllers on the market today. Available in either Black or Clear Blue cases, the PRofec B-spec uses a reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi., as well as a Balance knob to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates good for twin and sequential turbo setups. Compatible with the GReddy Remote Switching System."
http://www.nolimitmotorsport.com/2/greddy-profecb2.jpg
not trying to make a sale for nolimit...get it used for far cheaper!!!
remember, changes will store if they are done while moving
pull.... waitch the gauge(boost)
turn knob... pull and watch
switch to high... pull, watch... coast, make change pull again.
you now know the device
enjoy!!!!
enjoy!!!!
Garage (sort of)
