Ok, tried to get an e-test on my ZE (passed as a hot rod last time), and now they claim they can't get it to stay steady at 2500 rpm, after about 30 to 45 seconds it starts to hunt around.
Anyone had this issue before?
Car won't behave for e-test
seems like you got some kind of misfire man.. check yo spark plug..wire..cap,,rotor, if all seems ok..check your fuel sys.. injector clogin up..caz of cheap gas..hope ya aint running em cheap gas man..caz they'll do a number on your injector. next would be to check your fuel filter for restriction..n finally pressure regulator..for leaks .. that should cover everything..
lol,. ever since i install my ze..never got any problem..none ..nothing.. you people out there are weird..
93' blue mx-3, klze curve neck, kl36ecu, all the upgrade possible/out turbo.
