problems shifting
- gapimpin
problems shifting
im having a problem getting my car into first and sometimes reverse every other gear works fine. to get it in first most of the time i have to let the car role a little and it makes a crunch when it enguages but some times it will go in smooth as can be could this be my bushings the controol rod just not following the gate. i was thinking about getting some of those bronzeoil bushings but i want to know if that will fix it before i shell out $80 for the whole set.
jimishadow
Mazda_Power
- gapimpin
ive never had a problem with second but a cold front just hit texas and thismorning my first gear was fine but it was grinding into second until it warmed up. well i guess its still doing good for a tranny with 200,000mi on the clock. you think if i change the fluid it would help any? or is their anything else i can do just to improve the shifting?
- Typhoonk
change the fluid in your tranny every -> 30,000km, 2yrs or when the colour of the fluid changes colour, or you are having problems
any other ideas?
any other ideas?
PM for info
PM for info
If the problem occurs when you first try to put the car in gear after you start, then I have the same 'problem' too... happend yesterday shifting into reverse. I just roll or put the car into another gear and then try again and it's good to go. I had the bushings replaced 3 years ago and it didn't make a difference for me - it still happens 5 or 6 times a year.
1996 MX3 RS - Toronto
cdngrl420
exact same thing with my car im going in to get the tranny fluid changed real soon so if i notice any improvements ill tell u, but what i recall the mechanic telling me is that soemthing inside the gearbox has worn down since you go from 1st to 2nd the most and it doesn't hurt the tranny any, then i got advice from my dad to just be easy and hold the clutch in for a few secs and shift real slow when shifting between those gears especially when the car is not warmed up, don't down shift into that gear jus throw it in neutral when its being a pain, just becarefull because sometimes it pops out of second and into neutral or you will feel a slight crunching and it feels like its not going all the way down.gapimpin wrote:ive never had a problem with second but a cold front just hit texas and thismorning my first gear was fine but it was grinding into second until it warmed up. well i guess its still doing good for a tranny with 200,000mi on the clock. you think if i change the fluid it would help any? or is their anything else i can do just to improve the shifting?
