turbo goodies galore- bpt upgrade package inside
popsicle
Post by popsicle »
this won't last very long...
here is what is being offered for the BP, BPT motors. some of the items will fit other motors.
a T3 upgrade kit with the following components,
-air research T3 turbo, recently rebuilt with less than 1000 miiles on the turbo.
-custom log style manifold with greddy wastegate port already welded
-downpipe flange with 4" section of a 2.5" downpipe
-complete SS oil line kit. this includes the nipple to go on the block, the SS line for the oil feed, and oil restrictor(30 bucks from ebay). oil drain also included.
priced to sell at a mere 650+ shipping.
some pictures
knock controller
60 trim housing and compressor wheel
some quick notes
-this is what you need. if you are already boosted with a fmic setup all you'll have to do is cut your compressor outlet flange and use a coupler to attach to the T3 outlet.
-the greddy external wastegate is available to purchase. it's a 48mm wastegate, retails for 850 new. will sell for 600. comes with everything includeing gaskets and bolts.-600 usd
- buyer has the option of purchasing a T3 compressor wheel and compressor housing for even bigger hp gains. but note! proper fuel management is highly adviced. adding the 60trim compressor housing will make your 1st 3 gears useless. not for the faint of heart.- 100 usd
other things for sale
-gtx 330 cc injectors-80 usd shipped
-gtx knock sensor unit-25usd shipped=SOLD
-gtx knock controller unit-30usd shipped- SALE PENDING
more items will be added as well as pictures toinight.
