FS: 92 style seats and GS lip *pics added*
I have 2 things for sale I have a black gs lip good condition it just needs to be sanded and repainted and I also have 92 style seats they are in very good condition they just need a good steam cleaning they are dark blue with green inserts on them! 50 for the seats 50 for the lip prices can be negotiated
Always under construction
- atlantamx3
- jschrauwen
- PATDIESEL
The lips are not fiberglass and cannot be fixed with fiberglass. If you try to fix it with fiberglass it would look great for about 2 days untill you bumped it on something and the Urethane lip bends and the fiberglass doesn't. The fiberglass is not flexible like the lip and will seperate from the lip at the first tap. Use a good epoxy and then sand and paint, that should last a bit longer, but there is not real good permanant fix.
reaper of souls
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
