Klze computer ?
Klze computer ?
Hello everyone, I remember seeing a post that showed dyno runs of a klze using different vaf and computer setups. Does anyone know where that post is? I have an apec 2.5 vaf and computer, I also have the 1.8 vaf and computer. Which do i use?
- jschrauwen
Re: Klze computer ?
Since you have not come right out and clearly said that you have a KLZE engine, I will assume that you have a KLDE. In which case, a KL01 ECU and a KL02 VAF will work just nicely.ncmx3 wrote:Hello everyone, I remember seeing a post that showed dyno runs of a klze using different vaf and computer setups. Does anyone know where that post is? I have an apec 2.5 vaf and computer, I also have the 1.8 vaf and computer. Which do i use?
