KFZE gasket and injector questions
I have a KFZE in my MS-8, and I am having some issues. I pulled the front plugs, and noticed that the one closest to the oil cap was black, the middle was white, and the one closest to the PCV valve was white, and coated in oil. I was told that I have a leaky VC gasket and injector. Don't really want to buy the parts here, as Japanese prices are rediculous for anything.
Anyway, I was told to check this place out and find info. If you can offer suggestions, please let me know. Like if the VC gasket crosses to anything else, in the states, so I can pick one up in December, and if there are any FAQ's that I am too noob to miss.
hgallegos915
cant you use klde injectors? i think those would work. Leaking injectors IS DANGEROUS..if your wires begin to arc if WILL catch fire...i can tell you from experience..
-hec
- papa roached
the part thats leaking is a injector gasket type thing, they all interchange
How rough is it to get to them? the IM has to come off right? I don’t know if leaking is the right word. I just know that it’s causing my front bank to adjust, and run the other cylinders lean, and my mileage isn’t what I think it should be. I haven’t seen or smelt any fuel, I think that the injector is just leaking into the cylinder.
hgallegos915
they come opff right away, you need a hex key, and are simple..i did it the first time in around 15 minutes. easier when the im is off...WAY easier. That way you can give a good cleaning toi your valves..use carb cleaner and a toothbrush
mine are squeaky clean.
-hec
hgallegos915
the bottom rubber seals and make sure you put the tight but dont break the bolts. If you leave a seal out it will leak.
-hec
Mnemonic
he could use klde injectors but they will lean out his car, as the kfze injectors are the same as the klze injectors.hgallegos915 wrote:cant you use klde injectors? i think those would work. Leaking injectors IS DANGEROUS..if your wires begin to arc if WILL catch fire...i can tell you from experience..
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
hgallegos915
Really? :O so does that mean I am running lean???? :O !!! or he has the 170hp kf?
-hec
Mnemonic
prolly means your running a little lean, me and custommx3 both confirmed that the klze and kfze use the same injectors
hgallegos915
holy cow! that is new information for me..even if im running a little lean.. and I have a feeling i had since i first had the engine in.. i would love to get the kost of it... anychance can I use same fuel pump? or have to update?? hey sorry not jacking the thread as far as part numbers any k series injector gasket fits.
-hec
