Page 1 of 2
Shorter shifter install problems
Posted: October 12th, 2005, 10:50 am
by bulaian
Hey, I just purchased this shifter
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 8002625781
and i'm having problems installing it. I was able to get my old shifter out fine but when I try to install this one, I noticed there's nothing keeping the shifter itself from sliding out to the bottom out of my car and hitting the exhaust piping.
I was wondering if anyone else out there with a sts with this type of housing had any problems like this or if i'm just dumb or if my shifter is broken?
thanks a lot.
Posted: October 12th, 2005, 2:29 pm
by mitmaks
anything else came with shifter, some kind of hardware to install it. like clip or something
Posted: October 12th, 2005, 3:29 pm
by bulaian
it was late last night and i was getting really frustrated at everything so I didn't look too closely. I'm off work in an hour so I'm going to check again. I'll post more if I have more problems
Posted: October 13th, 2005, 8:30 am
by bulaian
Ok i got it installed and everything now but it's wobbly as hell. the base of the shifter, where it connects to the linkage is not as wide as the stock one. my only thoughts on this is to fit in some washers to fill the space. any other solutions ot this problem?
Posted: October 13th, 2005, 11:59 am
by mitmaks
possibly got wrong part
I think theres supposed to be bushings to go in there
Posted: October 16th, 2005, 12:12 am
by bulaian
if anyone cares... I bought some stock bushings from the mazda dealership for about $12. The Shifter Extension rod Bushing and just the regular plastic shifter bushings and the shifter is tighter than it has ever been with the stock shifter before it.
Posted: October 16th, 2005, 7:04 pm
by Legato626
mine is lose to and i got a B&M that i got from ebay. Mine is getting stiffer tho but i like it nice and lose because i know it wont stick then when i am racing auto cross =)
Posted: October 16th, 2005, 8:52 pm
by bulaian
lol it was waaaaaay too lose before though, the top of my shift know could sway back and forth about 2 inches, when it was in gear
Posted: October 16th, 2005, 9:06 pm
by Legato626
ya mine does that to, it doesnt bother me i like it like that makes it lose and easy to put in gear good for racing
Posted: October 16th, 2005, 11:27 pm
by bulaian
really???? i don't mind maybe a cm of give or so but like 2 inches was crazy... i didn;t even know if i was in gear sometimes
Posted: October 19th, 2005, 5:04 pm
by ooELMOoo
You take your old white circle thingys
that you took out of your old shifter and put them on your new one...Then you take the little black rubber bands of and it slides right it.....then if you dont like it lose you take those rubber bands and place them under your car where the shifter comes down ....then it stays nice and tight....but i love the lossness
when my car is in 4th gear i can have it like its almost in second so its comfotable and fast to change gears
Posted: October 19th, 2005, 7:42 pm
by Legato626
He is unable to use the round things the new shifter comes with them on it. He is basicly have to live with it. =) you get use to it after time.
Posted: October 19th, 2005, 7:43 pm
by Legato626
You could try putting some greace in the ball part see if that will make it stiffer.
Posted: October 19th, 2005, 10:30 pm
by bulaian
I can't use those white circle things, since it comes with aluminum housing. kinda odd, there's no ball either, in the middle of the housing, it's kind of like a ball but the shifter goes straight throgh the middle of it. oh well, i love how it is now though.
Posted: October 21st, 2005, 7:57 pm
by freyguy_412
I got the ebay shifter too... not the best part but it works lol...
For your loose problem: Take washers and start slippin them between the fork and the bottom of the shifter. They won't fit the best, but no one will ever see them so it's not a huge deal in my opinion (Haven't tried the SRD bushings, but I plan on it "someday".) That should tighten it up quite a bit. Mine felt really solid after I did it. Just DO NOT over torque that nut or else you'll have serious problems going into 1,2,5 and R cause you will restrict the shifters movement. Get it snug but don't tighten the s--- out of it.
For the falling problem: Somewhere on here a gentalmen is selling a small bracket that screws to your car and covers the shift hole from the bottom. Your shifter basically rests on that tab and stays put. Looks like a good design. I on the otherhand am a cheap a-- bastard, so I took small zip ties, linked enough together to go around the shifter. The nubs of the zip ties keep the lip of that part just above the floor and in a great position. Just make sure you get those zip ties really tight or else they will slip off and let your shifter drop again.....
