oilaholic oil troubles
nyzmx3
Post by nyzmx3 »
ok im in need of help from anyone...my mech tells me i have a leak coming from the head gasket. a couple of months ago with this b.s. rubber cement like stuff but now its drinking oil like water and still leaking is there any other solutions???
Shades
Post by Shades »
If it's leaking oil there is no solutions other than to change the head gasket.
Our engines tend to leak out on the exhaust side where the drain back holes are. Right in the corners.
"Do it ONCE, do it RIGHT!"
nyzmx3
Post by nyzmx3 »
would anyone happen to know how much the head gasket would run? u.s.$$
Mazda_Power
Post by Mazda_Power »
About $50.
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
neutral
Post by neutral »
http://www.rockauto.com has em for your 94 model at a cost of ~$32 USD for just the head gasket, and ~$102 for a head gasket set.
You definitely meant "head gasket" and not "valve cover gasket" correct? Cuz the valve cover gasket leaking oil is a much more common prob.
Image -Jim
Mazda_Power
Very True...
nyzmx3
Post by nyzmx3 »
yep the head gasket is whats leaking.....thnx for the info
mlinterman
Post by mlinterman »
I seem to be having a big problem. My car exaust shoots out blue smoke like I am burning oil everytime I start it until the engine warms up. Is this a similar problem where I just need to replace my headgasket?
rusty
Post by rusty »
Sounds like your valve seals are done if it only burns oil when you start it. This is because the seals are hard and will leak oil into the cylinder when it's not running and when you start it, it burns off all that oil when you start it. once the engine warms up the seals soften up from the heat. So they won't leak (as bad) anyways.
