Well with everything finally buttoned up i went for a spin, boosts nice till 4k then almost hits a wall and my Wideband goes into the higher 13's which is when i let off.I figured it was my fuel maps (safc2) so i richened it up, no change, and then i went nuts and added 20% and still the same. Im still running the stock Mx-3 fuel pump (yea i know i know) and the 330's from the b6t. Should this be happening at around 10 lbs of boost? Or do i have problems in other places? part throttle and below 4k is perfect, dosent go above 12.2 but once it does it goes lean.
Which rx-7 pump should i buy? THe second gen 255 high or low pressure?
Ill be changing the filter tomarrow.
Thanks Guys
Believe I maxed my fuel pump. HElp!
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
Thanks Bugs!
So one like this guy will be fine?
http://cgi.ebay.com/ebaymotors/WALBRO-F ... enameZWDVW
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
- XxantwawnxX
yes it will fit, although not perfectly...its a tad bit tighter...but you DONT need any mods : ). Ive had th e3rd gen rx7 pump in my mx for years....and im not even turboed yet(was planning on it) Now im finally getting started on th eproject.
