neither will work, they are not 4x100, those are 4x108 and 4x114
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
bmwm3guy wrote:cant find any pics but a good friend of mine did it soo...
Well I'd like some info on this then.
The bearing diameter is different from the mx3 to mx6/probe/626
98 Ford Ranger 3.0L
I have been looking into this as well...and i can see the fronts fitting without a problem, but the strut used has to be from a Probe/MX-6.
The rears mount differently, so i am sure some kinda modifications have to be made....and i never really looked at doing it any further, after seeing it was direct bolt on.
Guys- do some research... this has been brought up, discuseed, and shot down more than enough times to prove that its not a bolt on affair with the probe/mx-6/626/millenia stuff.
The only car's spindles I can see even being possible to fit on the MX-3 is the 5-lug GTR... but good luck finding them!
Although I am still not sure WHY you would want to do a 5-lug conversion. Its not a "JDM" option and there are just as many wheels for the 4x100 bolt pattern as there are for 5-lugs.
PS, the Astina isthe 323F or Lantis. Same chasis as the MX-3 so it would be a direct swap. Problem is that the number of countries that the Lantis was sold is are few.
So would I, but I searched last night for more pics of the Astina (323f) and couldn't find any with 5 lug wheels. All of them had 4 lug that I saw. I know that most cars I saw were 4 bangers, so maybe I need a pic of the 323f with a V6???
Maybe one of the Australian guys would ship us a set or two...
