Intermitant wipers NFG
If you have a look here:
http://www.mx3er.com/Info/1993%20Wiring%20Diagrams.pdf
Figure 9, grid position CD 34/35 you'll see the intermittant controls are all built into the switch. So unfortunately you're probably up for a new switch as I don't think you could pull it apart and repair...
