KEY LIGHT
acespdz
KEY LIGHT
Post by acespdz »
Does Anyone know if there is supposed to be a light that goes on where the ignition is so that you can see where the key goes??
ninjajim4
Post by ninjajim4 »
yes there is. it should glow green.
acespdz
Post by acespdz »
And how would I get this light to work cuz mine doesnt
Grants
BANNED Member
Post by Grants »
Pull the shrouds off the steering column - just a few philips head screws from underneath - and check the bulb.
cb mx3
Post by cb mx3 »
Since were asking questions about it, is it the same type of bulb thats in the dome light. Are they interchangeable. I'm asking this b/c I have blue lights from the dome that I would love to put there or is it green plastic that makes it green?
Hoodzy
Post by Hoodzy »
green plastic
1995 Creek Mica Blue GS
acespdz
Works
Post by acespdz »
Thanx alot I got the key light working, i'm going to see if I can get a friend who works with plastic to make me a different colour for the cover that is there. the one that is there is green i'm going to see if He can make different colours of that same size and shape. :pimp:
Grants
BANNED Member
Re: Works
Post by Grants »
acespdz wrote:Thanx alot I got the key light working, i'm going to see if I can get a friend who works with plastic to make me a different colour for the cover that is there. the one that is there is green i'm going to see if He can make different colours of that same size and shape. :pimp:
Let us know how you go - I'm sure there'd be other people interested too.
cb mx3
Post by cb mx3 »
Yeah, deffinately keep us posted. I was looking at that the other day wondering if there was anything I could do to change it myself.
acespdz
Post by acespdz »
Well Can't make the exact copy of the orignal piece but i'm thinking that if I use just a square shaped piece of plastic and use some sort of coloured tint it will work and we are also going to need stronger lights bulbs because the one that is stock is very SH**y and won't shine bright enough to notice the colour difference. The lite I got from CT is still not strong enough. If someone can find a strong Bulb that would help.
clear plastic and a permanent marker :D
Hoodzy
Post by Hoodzy »
maybe some clear blue hobby paint?
666raCing
Post by 666raCing »
My key hole light turns on and off. It doesnt stutter or anything, but one random time i open the car door and it's on. Other time's it's not. It's more often not on than on.
What can i do? I know the bulb is good and that it works.
Thanks.
92 Mazda MX-3 GS
jschrauwen
Post by jschrauwen »
666raCing wrote:My key hole light turns on and off. It doesnt stutter or anything, but one random time i open the car door and it's on. Other time's it's not. It's more often not on than on.
Thanks.
IIRC, the key illumination is to be triggered on when opening the car door. I believe it also is on a timer that starts at that point. That timer is ballparked to give adequate time for a person to find the keyslot in the dark - 5 maybe 10 seconds at most. It will shut itself off when timed out and will trigger back on again when/if the door is openned again.
666raCing
Post by 666raCing »
so does something have to be replaced? the iirc unit?
92 Mazda MX-3 GS
