how to work the air and heat?????
Jeff K
Post by Jeff K »
ok its a 92, i have fore settings for fan speeds and a thing aboute that thats somthing elss. Than theres the temp and vent settings and an a/c botten above all of that. but my 2 and 4 fan speeds dont work and than a/c only works when its on 1 can any one tell me if this is normal or help me.
Grants
BANNED Member
Post by Grants »
No thats not normal. Sounds like the fan switch might be shot, seeing the air con works ok on one speed only - it should work on all 4 speeds.
Jeff K
Post by Jeff K »
When i press in the a/c botten it only lights up when its on fan speed 1.
Mazda_Power
Post by Mazda_Power »
Mine is the same way. If you find out what's wrong, make sure you tell me too! :)
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
Grants
BANNED Member
Post by Grants »
Jeff K
Post by Jeff K »
Ok i try and see if that it i'll get back asap with that. o just a random thing i was thinking about repainting my car. I was thinking dark forest green with lots of silver sparkle what do you guys think.
Jeff K
Post by Jeff K »
bump*
relisys_3200
Post by relisys_3200 »
what color is it now?
Brandon
1992 MX-3 GS-ZE
Jeff K
Post by Jeff K »
its that normal emraled color
