FS Misc Parts
Trevor
FS Misc Parts
Post by Trevor »
power streering pump $25
k8 alt $40
ac compressor $40
white stock rear bumper $60 Pick up only
white driver and pass doors $25 ea Pickup only
white driver and pass mirrors $15 ea
2 black front mud guards $15 pair
92 dash pad $15
air box $10
ac Cooling unit $20
glove box $5
upper right side rs engine mount $25
10" Pioneer 300watt sub in a Ported sony explode box $50 pick up only.
K8 ECU $30
AC condenser $15
Condenser Fan $15
hgallegos915
Post by hgallegos915 »
Hey sell me your ac condencer and also the ac line that runs across the bottom that goes to that little freon container. Im at 79927 , those prices are awesome.. let me know please :) this is for a v6 i assume? if its rs ill check to see if its the same.. also got the water overflow tank? resevoir? i know any rs will fit a gs :)
-hec
reaper of souls
Post by reaper of souls »
hey trevor do you have any where i can get two new/used cooling fans i shorted one out and cooked both relays so i have one fan wired up manualy at thee moment
Image 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
slowmx3
Post by slowmx3 »
just so you know, you cannot use a receiver drier once it has been opened and exposed to air.
1992 mx-3, a couple mods, i'm still a n00b
---Don't try and church your car up, MX-3's aren't fast---
sweetmx3
Post by sweetmx3 »
trev the dash pad is that the whole dash cover if so i will take it. it is black right.
Trevor
Post by Trevor »
hgallegos915 send me a pic of the pipe your looking for. and yes the dash pad is black and it is the whole thing. PM me for more info
hgallegos915
slowmx3 wrote:just so you know, you cannot use a receiver drier once it has been opened and exposed to air.
whats receiver thing?
-hec
slowmx3
Post by slowmx3 »
its what stores A/C refrigerant and oil. And removes moisture and air from the system. So when you expose it to open air, it makes it useless.
Trevor
Post by Trevor »
slowmx3 wrote:its what stores A/C refrigerant and oil. And removes moisture and air from the system. So when you expose it to open air, it makes it useless.
Didn't know that. post edited and drier throwen out.
Trevor
Post by Trevor »
:bump:
