Engine ticking on cold start normal?
Chiggles
Post by Chiggles »
Maybe it's just that the weather is starting to get cold here and that I didn't notice this before when I first bought the car back in November last year, but lately, when I leave for work in the morning especially and the car first starts up, I can hear the engine ticking for about the first couple of minutes, but then the ticking goes away after the engine's completely warmed up. ...And I don't know if that's supposed to be normal or not.
My oil's at a good level, and it's relatively fresh since I just had it and the filter changed back in July. All seems to be fine, but I'm just curious as to why it would tick first thing in the morning when it's cold cuz it doesn't seem to do it 9 hours later when I leave work and start it up again to go home. Is it something I should be concerned about? For that matter, if it is, how do I fix it?
What I drive: A Cybertronian disguised in the form of a Creek Blue Mica 95 MX-3 GS. :driver:
Long term goal: Fabricating a new transformation cog! :welder:
jsx
Post by jsx »
i had that noise too, its the overhead cams, i was told.
after i did an oil chage, it went away.
try adding more oil
im not an expert but it worked for me.
MX-SLICK
Post by MX-SLICK »
these cars are known for it. Its hydraulic lifters I beleive. Make sure the oil level is ok and change the oil, and dont worry about it too much. The noise is simply a result of an older japaneese engine with some miles on it....No big deal. Mine does it in the cold mornings aswell. It is like a tapping that abruptly stops after 30 seconds or so and the motor is dead silent afterwords.
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
2000 kawasaki kx 500 MX
Mazderati
Post by Mazderati »
Mine does the same thing. If I use thicker oil it does it even worse. Hydraulic lifters.
8) 8)
96 GS, 17" Niche's, Falken 40's. Eibach springs, Tokico S/R struts, Ractive front & rear strutbars. Supertrapp exhaust, K & N intake. Soundstream Reference, JL & Eclipse audio.
Green means "Go", Yellow means, "Go Faster"!!
Chiggles
Post by Chiggles »
Ok, well now that we've determind noisy lifters is a common culprit, can anything be done about them? More importantly, is this an issue of some concern? If I don't do anything about it, will it hurt the engine long term?
lakersfan1
Post by lakersfan1 »
Make sure your oil is filled and start using 5W or 0W for the winter. Mine started ticking this week too with the first cold front.
Spinkx79
Post by Spinkx79 »
lakersfan1 wrote:Make sure your oil is filled and start using 5W or 0W for the winter. Mine started ticking this week too with the first cold front.
Switching to 5W should def help..incase some dont know, the "W" stands for Weight. And obviously 10W weighs more or is thicker than 5W.
g/l
lakersfan1
I believe the W actually stands for 'Winter', as it's only after the cold viscosity number. Could be wrong, but pretty sure that's right. Both numbers refer to weights.
Chiggles
Post by Chiggles »
BAM! That could be why I didn't notice any ticking when I bought the car last November. I had it winterized immediately right after I got it when I was having the fluids changed and the shop had put in 5W30 for me. Been using 10W30 on the last change in the spring. Great, so I just have to re-winterize it then. Thanks!! :D
mitmaks
Post by mitmaks »
what kind of oil filter are you using
mx3ze
Post by mx3ze »
It’s HLAs - Hydraulic Lash Adjusters, Lifters.
For more info please check this link.
http://homepage.ntlworld.com/dorothy.br ... x/p_p7.htm
Chiggles
Post by Chiggles »
mitmaks wrote:what kind of oil filter are you using
Crap, I can't remember exactly what make it was. I got it from Napa and it was one of their higher grade ones. :dunno:
Legato626
Post by Legato626 »
how i found to fix that clicking crap when start up (doesnt hurt anything just annoying...) But how i stop it is that every time i change my oil i put in a bottle of lucas oil stabilizer witch this stuff stops most of that ticking crap. Because it fills in and seals everything, stuff works great! And when the ticking comes back more often thats a good sign that you need to change your oil again.
you can find more info on http://www.lucasoil.com
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
