New KL turbo kit time
rebel2k4
Post by rebel2k4 »
Well, along with a built motor, I have decided to build a new turbo kit.
Already have all the parts, and this is the line up:
Holset HX40W turbo... these have been proven to 500+ WHP
Ebay bar/plate FMIC (yes, going intercooled, finally) 27 overallx6.5x3.5
2.5" mandrel pipes, equal length to turbo
2.5" mandrel IC pipes with silicone & tbolts
All MIG'ed by yours truely
Shooting for a bit under 500 whp, but a little over would be nice.
I have spent a total of a bit over $2000 in parts for the new turbo kit alone, ouch. Pics will follow shortly.
98 Ford Ranger 3.0L
onderground_mx3
Post by onderground_mx3 »
woot get those pics up....go0od luck ...
babyblueMX3
Post by babyblueMX3 »
glad things are going great for ya...keep it up
RIP 400whp ZE-T MX-3
Juans_93_MX3
Post by Juans_93_MX3 »
You still selling that old turbo kit Rebel?
I'm curious to see how your going to make about about 500hp
Last edited by Juans_93_MX3 on September 25th, 2005, 4:43 pm, edited 1 time in total.
2008 Mazda 3
1993 MX3 GS
fieromx3
Post by fieromx3 »
500whp good luck on that cant wait to c how it turns out for ya. after ur done take it to the track and share ur times with us. so what else ur u gonna do to actually get all that power to the ground?
fieromx3
Post by fieromx3 »
also what amount of boost u plan on puttin out?
rebel2k4
Post by rebel2k4 »
Thanks for the comments.
Due to the fact that I want to keep a/c, I cant run 3" piping, so 500 whp is probably out of the picture. The HX40 I bought also has bad seals and I dont feel like rebuilding so I'll be going with a smaller HX35 or H1C instead. I still plan on 450 hp or so.
I am still selling the old turbo kit. It is a good kit, of course not "professionally built" but very functional, no leaks or problems with it.
To get the power to the ground I'm buying real race slicks, 24.5x8 is what I plan on. For the street, well not much to do in the way of FWD for that.
Due to a series of events the car is on the back burner for a few months. Just bought a nissan pathfinder, putting a new motor in it and planning on boosting it as a powerful 4x4 reliable daily driver ;)
Planning on 20 psi or so on a built motor with race gas.
98 Ford Ranger 3.0L
mitmaks
Post by mitmaks »
its gonna be beast
rebel2k4
Pics finally
Post by rebel2k4 »
After about 50-60 hrs of work it is complete.
These are a few pics I snapped with bad lighting, I'll get more.
Drove it today, wastegate isnt right yet but hit 12 psi and it screams. Needs tuning in the worst way though....
poor stock bumper....
As always, a work in progress....
98 Ford Ranger 3.0L
fieromx3
Post by fieromx3 »
im so jealous rite now it aint funny. can u go out and do some 0-60 times and 0-100mph as well that way it will give an idewa how fast it is same with u babyblue thatd be great.
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
rebel2k4
Post by rebel2k4 »
fieromx3 wrote:im so jealous rite now it aint funny. can u go out and do some 0-60 times and 0-100mph as well that way it will give an idewa how fast it is same with u babyblue thatd be great.
0-60? On the speedo?
LOL... when I hit boost in 1st and shift to 2nd fast, my speedo sits a 60 mph, the tach at 7k, and smoke will literally pour off the tires sometimes. It is generally just a ton of screeching though as I burn all through 2nd gear
So that answers your question, 0-60 when I shift into 2nd gear. it does take a second or 2 maybe for the car to catch up to the speed of the tires. It's pretty crazy really. Anyone who rides in it when I do that has the same response.. "holy shlt." It used to do this with the other turbo on stock ecu/injectors and 10 psi too....
As for zero to 100 mph... hmm.. dunno man. 13.0 @ 110 is what I ran in the 1/4 with a kinda bad launch
98 Ford Ranger 3.0L
Selecta
Post by Selecta »
Wicked progess there man.
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
papa roached
Post by papa roached »
i got a new job....the cash will be flowing soon and hopefully a turbo too
Selecta
Post by Selecta »
Wicked...we can always use more boosted KLs to off-set the BPTs hehehehehe
Return to “Forced Induction”
