Little vid of me going fast
Cpl_Bryant
Post by Cpl_Bryant »
Little vid. I'll probably add it to my big video I plan to make, but check it out now anyway. Oh, by the way, as far as any police are concerned, this was done while the car was on jackstands, not really driving :wink:
http://members.aol.com/m0n0b0mber/speed.mov
http://www.cardomain.com/profile/cplbryant" onclick="window.open(this.href);return false;
PATDIESEL
Post by PATDIESEL »
Can't get it to load the page it just sits blank...
Cpl_Bryant
You need a .MOV player (like quicktime)
eppyhonda
Post by eppyhonda »
wouldn't work for me either
solo_ryder
Post by solo_ryder »
worked for me...ur car sounds funny for some reason
mitmaks
Post by mitmaks »
works for me
bmwm3guy
Post by bmwm3guy »
nice vid :P K8 I presume?
XxantwawnxX
Post by XxantwawnxX »
pfft you call 110 fast...was expecting at least 130 out of it...: ( ; ) : P
ccreech
Post by ccreech »
werd. It would have taken him a long time to get there though.
93 GS KLZE Straight Neck (Parked)
Green Turd of MOCA
Car Domain
Mnemonic
Post by Mnemonic »
110 i go faster than that with my shopping cart :)
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
kp2t
Post by kp2t »
oh dems fighting words LOL
Cpl_Bryant
BPT, I ran out of road, and yeah it does sound wierd. I get this metallic humming from around the driver side wheel or tranny or exhaust maybe I can't tell. I've been told my muffler moves around a lot more than it used to. It only makes that noise under a heavy load. :shrug:
Franko
Post by Franko »
If he has the g series tranny then the most he would be able to get out of it would be like 125.. I know this.. Ive done it..
Jteezy
Post by Jteezy »
I have the g series tranny, and i've done 140mph. The g series is short geared, which i see as an advantage. F series tranny gearing is nice, but the internals arent as beefy as a G series. Can you honestly tell me the tranny that was on your original 1.6L sohc 88hp (to the crank) will hold 300hp compared to a tranny thats on a built dohc 1.8......not a hard question to answer. I was actually thinking of doing a 5th gear swap into my g series tranny.
Mnemonic
Post by Mnemonic »
i got mine up to 134 so 125 isnt the fastest
