hey. i've been looking around and i know in the past there was a post describing which parts from which cars would fit on our cars, but i can't find it. i'm looking for eibach or tein lowering springs, but they are hard to find and expensive for our car. if i remember correctly, the 91-97 escort and early 90's 323 suspension parts would fit. am i wrong? are there any other car's that share our suspension?
any help is very much appreciated.
Springs from what car?
- ovendenk
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
- ovendenk
so, these would work. i'm gonna pick them up in cali when i'm there for a wedding next weekend.
http://cgi.ebay.com/ebaymotors/EIBACH-P ... enameZWDVW
There isn't much difference in weight between the mx-3 & the escort zx2. I looked it up & there is only like 50lbs. difference.but the spring rate would be different between the MX-3 and the Escort.
IMO I wouldn't get springs for the escort. I as well as a few others that have bought springs for an escort have a problem with the rear sitting about a 1 inch higher in the back than the front.
Mx-3 H&R springs are some of the stiffer ones for better handling.
I am going with those with the sprint springs for a protege for a 2in drop all around. I will probably end up ditching them for a slightly higher spring, as thats the setup thats on my 323, and its too low IMO as is.
GS + BP + T3 + 9lb flywheel - some dead weight =
- ovendenk
thanks guys. i bought the springs already cause time was running out, but i'll let you all know how she turned out.
