maybe im blind...but that does not look lowered... looks stock. Unless Im blind!
-hec
I cant tell you what the silver one is...but mine is INTRAX 1.75 drop...look ssimillar to that one. Mine use to ride a bit higher than that when i first got the springs, looked more like th esilver cars drop.
