Air Filter
Air Filter
Can I buy a reuseable air filter for a 4 cyl.? I bought a throw away one from canadian tire and it was $40!!!! I just need a stock filter. If so approx. how much?
im assuming you can as long as you properly mantain it?
-hec
what engine do u have? the sohc or dohc? i have a k&n for the dohc that i dont need anymore and its in good shape and it was used for about 6 months in the winter then i got a custom cai so yah pm if your intrested.
i had paid 85 cdn for mineand would sell it for 35 cdn+ shipping
id even get a cleaner kit for you if u want....
