Is there any tricks to making sideskirts? I am thinking of attempting fiberglass sideskirts but i am wondering how to form it to the car. do i just lay a piece of plastic against the side of the car and they lay a strip of fiberglass to get the shape of the car and go from there? should i just freestyle it or use plastic pieces to make a molding, etc. I am basically looking for tips from the guru's of sideskirts and bodykits. I am really facinated with making stuff with fiberglass and think this would be a worthy challenge. How would i attach it to the car, would I make tabs to screw it in where the stock mudflaps were and screw it in the bottom of the frame (make the sideskirt go under the car a bit to acheive this). do i need to screw in the top part of the sideskirt or would this be sufficient, i am planning to fiberglass it to my car when it is made. Thanks
Ryan
How to make sideskirts
- vozaday2000
You can make some ncie ones well copies..all you need is to wrap the originals with foilo or other material..then grease i think..and lay the fiberglas coating on it..first layer will be thjin..ad a bit of resin to make it thicker and keep adding layers until desided thickness is aquired. Ive made copies of wide body kits for cavaliers and came out great.. they came out so good that we ended up using the copies instead of originals.
-hec
- vozaday2000
i was thinking of starting out from scratch. I don't have the money to buy my own right now, since i am going to school again and school doesn't pay to well, so i thought it would be fun to make some from scratch.
- ScooterBovine
- Josh
the best stuff to use is the pink or blue foam used in houses. you can get a sheet of it for like under 5 to 10 bucks at almost any hardwhare store. you can shape it with a sander and a knife.
