http://cgi.ebay.com/ebaymotors/ws/eBayI ... %3AMT%3A12
It's actually a Mercedes M62 SC. Completely rebuilt/refurbished and like new with a warranty. Now for a few other bits before the install occurs.
Conservatively about 280 RWHP at about 6-7 psi. Nice thing is that IC is not required with this SC if it's kept under approximately 6-7 psi and it's clutch type so it's not always full time boost. When engaged there's extra oomph right from the get go (lower rpm's) with no turbo lag. Much cheaper set-up too, I can't imagine what Steve has sunk into his, but he's mentioned it's a lot. I think at any more than 6-7 psi I'd be looking at greater expenses wrt IC, stronger axles and stronger internals etc. Still want to maintain that everyday streetability aspect.DavidOS wrote:whats the max hp on that ?
taken from http://www.superchargersonline.com/content.asp?ID=76Like the roots, the throttle body must be placed before the compressor because it is a fixed displacement supercharger.
