Timing Belt Cover
Posted: August 28th, 2005, 11:06 pm
by KanadianIceMan
My father is having trouble taking off the cover
all bolts have been removed, here is a picture of where we are at.
more him because i have now refused to work with him as we are The father and son from West Coast Choppers. Paul and the other dude.
SO, here is a picture where we are at, shoudl this just remove easily or do we have to take off the other pully?
we have tried out impact gun on the pully, although it seems we need a heavier duty gun to break it free as it has not moved in a long time.
Posted: August 28th, 2005, 11:09 pm
by fry_81
use the plastics flexibility to your advantage, start with the back cover, its the easier one to get off, just wiggle it around and it will come off. and no you dont need to remove the crank pulley to get it off, its alot easier with it off, but its still easily done with it on.
Posted: August 28th, 2005, 11:15 pm
by KanadianIceMan
Does the Damper Pulley have to be taken off.
Posted: August 29th, 2005, 12:25 am
by kiwi_MX3
to get the " bleeping" cover off you got to undo the "bleeping"
crank shaft pulley which is tourqued to "bleeping" 250 Lb's or
more.
Don't flex the "bleeping" cover as it shatters.
"bleeping " good luck........
This post has been "bleeped" in the interest of fellow members
who feel the need for some authentic amercian chopper....
Posted: August 29th, 2005, 12:59 am
by KanadianIceMan
thanks for your "bleeping" help
