BP lack of power
krishna
BP lack of power
Post by krishna »
Just finished the j-spec swap and it drives starts, sounds fine.
When i hit the gas it sounds like its got 5 horses behind the wheels, it slowly picks up speed and i have to shift out of first at about 10 miles an hour, second is even worse then 6000 rpm = 30 miles an hour. any thoughts?
92' BP
Charles-
Typhoonk
Post by Typhoonk »
Do you smell fuel when u drive it? or exhaust? if not then ur probably running lean and have to adjust ur air/fuel mix
good luck :lol: :D :lol: :D
PM for info
BuGS
Post by BuGS »
or maybe you put the clutch in wrong, or you have a bad clutch
krishna
wont run
Post by krishna »
Clutch is fine, i put it in myself and its new... oem.
but i dont smell gas or anything when i drive it
its like
hi, im a car.. idrive... but i drive very very slow.
thats how it seems anyway...
im taking it to a shop tomorrow
its probly something just hooked up wrong.
the guy i bought the trans from in the first place put the clutch in backwards... and after a weeks of driving it shattered uhg... nothin like grinding tin pieces slidin around in my tranny drum.
sigh...
ill keep you updated if i fixed it or not tomorrow.
by the way, hows the project comin bugs?
92' BP
Charles-
Mazda_Power
Post by Mazda_Power »
Check your air flow sensor. Also check your mechanical (if you changed a timing belt), and your electric timing.
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
krishna
bp lack of power
Post by krishna »
Yeah, it was the timing belt, slipped forward two notches... problem solved :) thanks
92' BP
Charles-
