Timing Questions. Sohc ecu and Disty b6t engine.
nos92mx3
Post by nos92mx3 »
Well i have a few questions about how much timing i should be running on my b6t.
I asked a fellow employee about it and he said i would have to figure out how much timing the Sohc ecu adds as the rpms increase.
So does anyone have an idea?
Also Im only running 12* of timing on the b6t at the distributor. Should i be running more? Im going to give it a try wether or not i get an answer i just wanted possibly for someone from experience to guide me in the correct direction.
Thanks guys
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
BuGS
Post by BuGS »
Well this is what myself and another turbo BP guy are running
12-13 original timing than -.5 degree for every lb of boost. I am using a BTM to make the corrections but my base timing is 11 right now.
nos92mx3
Post by nos92mx3 »
Well I do not have anything to control the timing right now.
Ill be megasquirting soon.
Do you think i should retard my timing? a couple of degrees?
93' Rs-t BPT - Sold
BuGS
Post by BuGS »
How many psi are you running? I have noticed it I retard it more than 1 degree if I am under 5 than I lose power. So if you are running 4-5 I don't think so. Anything over that go ahead and retard it 1 or 2 degrees
nos92mx3
Post by nos92mx3 »
yea im running 14 lbs.
Now when i checked my plugs i didnt see any metal specs, now that was only after about 15 miles.
So what your saying is i should lower my timing down to around 10*?
93' Rs-t BPT - Sold
D323
Post by D323 »
I thought that if you ran the SOHC ecu, you didnt need to retard the timing since the SOHC has less advance than the DOHC one.
GS + BP + T3 + 9lb flywheel - some dead weight = ;)
BuGS
Post by BuGS »
that is true. But it is suggest to only run it at like 15-20 psi :)
nos92mx3
Post by nos92mx3 »
heh 20 lbs on the vj-14.
HA!
93' Rs-t BPT - Sold
Return to “Forced Induction”
