6psi klde
mitmaks
6psi klde
Post by mitmaks »
how much approximate hp am I looking at with 6psi on kl-de?
PATDIESEL
Post by PATDIESEL »
Probably around 220-250, depending on engine management and other factors.
Scientifically, and without any factors such as friction, 12 Lbs. of boost doubles the out-put of a motor.
babyblueMX3
Post by babyblueMX3 »
PATDIESEL wrote:Probably around 220-250, depending on engine management and other factors.
yeah those numbers look decent.
RIP 400whp ZE-T MX-3
bmwm3guy
Post by bmwm3guy »
PATDIESEL wrote:Scientifically, and without any factors such as friction, 12 Lbs. of boost doubles the out-put of a motor.
Wouldn't it be 14.5lbs? 1 Bar = 14.5lbs so in order to double the air coming into the motor, you'd need 14.5lbs of boost.
babyblueMX3
I think that would be correct Eric
since the absolute pressure is 14.7 (0 manifold pressure)if you add another 14.7 psi (manifold pressurE) you double the air entering the engine.
jschrauwen
Post by jschrauwen »
Judging by the info available on PT boosting a DE is not such a good idea due to weaker internals, specifically the bottom end. I think they mentioned that you'd be flirting with danger anything over 6psi. I believe a ZE bottom end is a little stronger for something like that or rebuilding the bottom end of a DE as in the case of Spinkx79. FWIW
babyblueMX3
jschrauwen wrote:Judging by the info available on PT boosting a DE is not such a good idea due to weaker internals, specifically the bottom end. I think they mentioned that you'd be flirting with danger anything over 6psi. I believe a ZE bottom end is a little stronger for something like that or rebuilding the bottom end of a DE as in the case of Spinkx79. FWIW
the ze bottom end is the exact same as the DE bottom end (minus the pistons shape)
PATDIESEL
Post by PATDIESEL »
Thanks for the correction on 1 Bar. I knew that, but don't know why I posted 12Lbs. :roll:
MX-3 Money
Post by MX-3 Money »
wow, we got a science lesson going on here.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
mitmaks
Post by mitmaks »
what about kfze, good choice for boost? I can pick up one locally cheap $300
jaydog5678
Post by jaydog5678 »
We have a member here in Atl. that has a DE bottom end with ZE heads and cams. He's running about 7 lbs of boost through his Mitsu turbo on stock injectors with no problems so far. I don't think there is any difference in the bottom end besides the comp. ratio. They both (ZE,DE)_ have forged cranks and rods. Strength really is not an issue at low boost below 10 lbs. The correct fuel and ignition timing will allow you to run a higher boost on both engines.
A KF has the same forged internals, minus the pistons but it still has the 10 to 1 comp like the ZE.
Return to “Forced Induction”
