ok well i blew up the tranny in my car ( 92 MX-3 1.6L SOHC 5-speed ) so i decied to buy a new one and the only thing i found around was a tranny out of a 1992 mazda 323 with 55k manual and thats what i need so i bought it and am going to pick it up this friday and what i am wondering if anyone knows for sure that it will work ? i think it will because it is a mazda F-series tranny. but if anyone knows that it wont or has anythoughts pleases tell me before its to late and i waste the $425 US i am getting it for
Thanks
323 Transmission
323 Transmission
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
- papa roached
it will work fine
do you know if i will need the speedo cable for the 323 trans ? and if i dont need it can i use one from that tranny because mine is broken
Thanks
Thanks
CTC Racing
92 1.6L
92 1.6L
