Had some bad traction problems.
Here is my best run
R/T .343
60' 2.240
330' 6.370
1/8 9.778
MPH 72.37
I did have a run where I went 73.04 MPH. Not bad for a stock exhaust and street tires. I need to open her up and get some slicks and I should be in the low 9's pretty easy. I also am only running 10psi.
1/8 Mile times
osargeant
Approximately what sort of 1/4 mile time would this be equivalent to?
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- babyblueMX3
Re: 1/8 Mile times
when I was N/A last year this was my result:TEAMpK wrote:Had some bad traction problems.
Here is my best run
R/T .343
60' 2.240
330' 6.370
1/8 9.778
MPH 72.37
R/T .931
60' 2.175
330' 6.399
1/8 9.351
MPH 78.345
and that equals to 14.565 @ 94.443 on the 1/4 mile (same run actually)
weird thing is I had a better 60' than you, you had better 330' than I, and I had better 1/8th mile. lol
RIP 400whp ZE-T MX-3
