SAFC Map
- TEAMpK
SAFC Map
I am running a B6T. Stock injectors...Walbro 255 in line pump and a FMU. If anyone has the same setup and is tuned, let me know your SAFC mapping. I'm runing uber rich and I wanna try to fix it. Thanks.
forcedairram
map
I dont think anyone elses map will help you out all that much, being as temp, humidity, elevation etc will change how you tune, all you have to do is just play with it till you get it right.
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
