Anyone heard of MAP ECU products? Want to get rid of MAF??
cjthor
Post by cjthor »
check it out!
http://www.mapecu.com
Corksport sells it. It is basically a piggyback that controls fuel and eliminates your MAF sensor with a MAP...im thinkin bout it seriously....
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
nope-mx3
Post by nope-mx3 »
Consider doing a Megasquirt instead. Lots cheaper.
That way you can remove the entire stock ecu.
nope-mx3
cjthor
Post by cjthor »
nope-mx3 wrote:Consider doing a Megasquirt instead. Lots cheaper.
nope-mx3
That starts a wiring nightmare that I dont want to get into...
Jarid Perry
nope-mx3
Post by nope-mx3 »
wiring nightmare?
You use the stock wiring harness, thats what I`m going to do.
$650 for a piggyback is just ridiculous imho.
nope-mx3
osargeant
Post by osargeant »
I must say that I find this MAP ECU to be fairly expensive considering it only does fuel when other piggybacks like PerfectPower SMT6 and Greddy E-Manage handle both fuel and ignition control.
At $650us you are heading really close to full standalone territory and full ECU options like the Haltech,SDS or MicroTech would be more practical IMHO.
Just my 2cents. :)
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
papa roached
Post by papa roached »
i dont think this would be much less of a wiring hassel
cjthor
Post by cjthor »
papa roached wrote:i dont think this would be much less of a wiring hassel
Dont you have to assemble the megasquirt?
Jarid Perry
papa roached
you can buy it preassembled, its like $270 USD, in that area i think + the cost of a few other things and your ready to install
cjthor
Post by cjthor »
papa roached wrote:you can buy it preassembled, its like $270 USD, in that area i think + the cost of a few other things and your ready to install
where? ANd how hard is it? Has anyone done a four cyl mx3
Jarid Perry
nos92mx3
Post by nos92mx3 »
Ive seen Megasquirt v 3.0 on ebay completely assembled and tested along with all the sensors you need and the wiring harness as well for like 370 + Shipping.
This is pretty much a standalone 12x12 fuel and spark tables, not to mention lots of other stuff.
Im going to Give it the ole' college try within the next month or two.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
atlantamx3
Post by atlantamx3 »
Geesh Jarid... you are soundig like a Newbie....
Megasquirt & Spark will do just about aything for you. There is a large support community for them as well to help you work out any bugs or problems.
~Perry
Please visit
http://www.mx3-atlanta.com
BuGS
Post by BuGS »
Some ppl say to stay away from Megasquirt but I think they are great cause you pay for what you need, not any extra stuff you can't ever use like VTEC stuff...
Return to “Forced Induction”
