Clutch question
kljordan
Clutch question
Post by kljordan »
Ok i have a ZE and obviously the JDM tranny also.. i was wondering if the MX-6 OEM clutch is compatible with the JDM tranny or not. I"m looking to get a stage II for my car but want to make sure i order the right part. I'll probably be ordering the Stage II from them and prolly no possible way to return wrong part so anything you guys can help me with would be great. Thanks
Also when switching over to stage II will i need to get a new flywheel or just stick with the one that i have now. Please let me know asap
Anyone from the Indiana area.. or going to Indianapolis Import and truck bash in Indianapolis? If so we could meet up there and check each other rides
PATDIESEL
Post by PATDIESEL »
JDM manual or auto trans? You can use the K8 flywheel (it weighs alot less than a MX-6 version) or get the Fidanza for even less weight. All KL series motors use the same manual tranny except the LSD versions which still use the same clutch. You can get any MX-6 2.5L, Probe 2.5L or MX-3 GS clutch. I recommend a Spec or ACT clutch.
kljordan
Post by kljordan »
OKi thx for the help im looking at this clutch right now...
http://www.clutchcityonline.com/spec/mazda_mx6.htm
obviously the 2.5L ONE Stage II so hopefullly i can get it ordered here soon. How long do the racing clutchs usually last i dont know anyone with one. Just curious thank you
NoRtSeVEn
Post by NoRtSeVEn »
im looking at new clutches as i still got the standard one in and is on its way to the grave, wondered how the drivabilty was affected with any of those clutches on the site?
im guessing, only a guess but you could get one driver who kills a clutch in 6 months while it lasts 10 years for someone else.
