I am running the stock KL48 ECU to control the IAC, fuel pump, and fans, but other than that megasquirt is running fuel and spark. I also got rid of the VAF
I am running SR20DE injectors (260cc redtops) in modded stock fuel rails. I used a dremel and shaved the tops to make them flow 550cc.
I have been tuning a LOT lately, and have a pretty good VE table built now. anyone planning to run the 550cc modded redtops, let me know, I can hook you up with my settings. It is mapped to 20 psi of boost, with a lot of resolution in the lower kpa settings for cruising.
It took about 3 hrs to get to the point I am now as far as tuning is concerned. I had to change everything, from cranking, to afterstart, to acceleration enrichments to get it to run somewhat like stock with the 550's.
I am getting almost 20 MPG now, vs. 25 mpg of stock. I think with some more tuning, I can get it back to the 25mpg range. An LM1 wideband DEFINATELY helps with the tuning.
Here's a couple pics I snapped. I ditched the FMU, vaf, extra injectors, etc. so underhood is actually cleaner. I will take some pics after I redo my charge pipe and install my millenia mani, now that I no longer need a VAF
The brain....
![Image](http://www.supermotors.org/getfile/226404/fullsize/Im001027.jpg)
Modded nissan injectors in modded stock rails...
![Image](http://www.supermotors.org/getfile/226399/fullsize/Im001098.jpg)
Tuning station... (yes, crappy pic, sunlight to blame)
![Image](http://www.supermotors.org/getfile/226401/fullsize/Im001102.jpg)
And installed. Taps off stock ecu for many of the connections. With the stock trim pieces in place, you never know it's there...
![Image](http://www.supermotors.org/getfile/226400/original/Im001101.jpg)
For now I am running stock disty for ignition. Had to do the pullup mods to use it, but they are very simple. All I have left to do it loom the harness under the hood and add some resistors to kill the CEL, since I dont have the VAF anymore.[/img]
