confused about replacing my clutch!?!?!
i want to put either a stage 1 or stage 2 clutch in my 92 mx-3 gs (k8 v6) but i can only find clutches for the 94-95? would they fit my 92? whats the difference if not? im really confused about this PLEASE HELP!
- XxantwawnxX
they will fit.
