engine flush
Posted: July 16th, 2005, 5:15 am
Has anyone done an engine flush? Sometimes I see the reservoir with brown dirty water. I think it keeps on clogging up the radiator.
Yea, you're talking about a radiator flush rather than engine flush. Brown discolored coolant usually indicates old coolant and rusty corrosion/scaling in the cooling system. You can get a professional power flush or for DIY, try a bottle of rad flush from any autoparts store. Just be sure to follow the flush-mftr directions and be sure the system runs clear before refilling with fresh coolant.lucky13 wrote:Has anyone done an engine flush? Sometimes I see the reservoir with brown dirty water. I think it keeps on clogging up the radiator.
