engine flush
engine flush
Has anyone done an engine flush? Sometimes I see the reservoir with brown dirty water. I think it keeps on clogging up the radiator.
if you mean your rad is clogged then your looking for a rad flush. you can
get any jiffy lube or whatever your drive through lube shops are for like 30 bucks. 10 minutes job and its done.
- mitmaks
you mean brown coolant? did you check oil? does it look milky? maybe a sign of blown head gasket
- neutral
Re: engine flush
Yea, you're talking about a radiator flush rather than engine flush. Brown discolored coolant usually indicates old coolant and rusty corrosion/scaling in the cooling system. You can get a professional power flush or for DIY, try a bottle of rad flush from any autoparts store. Just be sure to follow the flush-mftr directions and be sure the system runs clear before refilling with fresh coolant.lucky13 wrote:Has anyone done an engine flush? Sometimes I see the reservoir with brown dirty water. I think it keeps on clogging up the radiator.
-Jim
