Problem wiht Nology
Problem wiht Nology
Ater I put the Nology hotwire in my K8, It works worse than the OE wire,NGK. The engine runs very rough, not smooth at all. Does someone know what problem is?
Chutipong Ampornpan
Black 1994 MX-3 GS Auto.
- mitmaks
make sure you didnt cross wires, I change mine one wire at a time. also make sure contacts are all the way snapped on spark plugs and inside dist cap contacts.
