CAI INSTALL question
- Hoodzy
ok so i was lookin over it prepping to install my integra intake and i noticed 2-3 hoses attatched to the bottom section of the airbox, with the little mitsubishi logo. so i'm gettin rid of the entire airbox right so where do those go?
am i lookin at drilling holes into the CAI an attaching them into that??
if so what part
thanks!!
if so what part
thanks!!
1995 Creek Mica Blue GS
- solo_ryder
- jschrauwen
Hoodzy, I've got an idea. Since you've got about 200 posts under your belt, I'm sure you are well versed with the search function. Augment that search with the technical info from the on-line shop manual. Print out a copy of the vaccum layout/diagram and thoroughly go over it...over and over again. With copy in hand and physically looking into the engine bay, trace the relevant parts of that diagam's layout as it pertains to your CAI install. Previous BB member's posts with a plethera of pics, their own car domain sites, the manual and just good old common sense will be more than adequate to get you through this relatively simple mod. I'm sure that after 200 posts you are familiar with the term "spoon fed". Let us know how your CAI turns out.....YOU'LL DO JUST FINE!!!!
- Hoodzy
i love u
- Hoodzy
and no i wont do just fine i managed to get the check engine light and all i did was take off a piece of the stock intakea nd put it back haahaHoodzy wrote:i love u
- jschrauwen
OK, first, what piece? If you want specific answers you need to provide specific details. I'm going to assume that it's the flex tube between the TB and the VAF. By now you must be quite familiar with the inherent/potential problems with the accordian style flex tube. If not kept completely clean and maintained they will, over time degradate, split, crack to a point that you will get a vaccum leak. Vaccum leaks are a bad thing so check your tube to ensure it's integrity. How do you do that? Good question, couple of ways. Use a small refill bottle for butane lighters that can be released by hand control. While the engine is running spray in patterns around the accordian tubing. If the idle speed picks up (goes higher) than you've found the leak. Conversely, you can use a water bottle/misting spray type and do the same procedure. The results will be a slowing of the idle speed.
[Saw your post in TPS thread] Since you know how to pull codes, did you go to the online manual (page F2-86) and follow the instructions there? Did you disconnect or break the TPS connector by mistake while removing the accordian tubing since it's in close proximity?
Don't get discouraged. We all break and f*ck things up from time to time, even the pro's. Post back after you've gone through some of this stuff and we'll take it from there. You'll get through this.
PS The on-line manual is your friend.
- Hoodzy
yah it was the black tubing, no cracks or anything.
u mean page F2-083 right??
yah i must have done something to the tps, dont know what though ahha
its saying alot is their continuity and increase voltage etc between terminals am i going to need a voltmeter or something to hook into the ECM?
Welcome to my world Hoodzy, Mine did the same thing when I got my intake on. Let me know when the misfiring starts coupled with the loss of HP starts. Anyways, make sure you leave the 3 tubes attached to that thing with the DSM logo on it. I retardedly took mine all off and left it that way for awhile and things haven't been the same since.
- jschrauwen
- Hoodzy
when i took off the black intake hosing
and to check to see wtf was going on with my TPS right were the intake attatches to the engine it is slightly grimey, if i cleaned that would that get rid of my check engine light??
ur mx is white?jschrauwen wrote:I've got the exact same CAI off of ebay also and this is what I have so far.
clean that engine bay up some y0. Simple green & a toothbrush & some water....scrub it up w/brush and rinse off w/water, will make it looks awexome
& nice intake install, my civic si intake doesn't have as many angled bends as that one
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- jschrauwen
I've been thinking about that ever since I decided to take it off the road for the winters last last year. It looks like shyt because that's the original rustproofing that the original owner put on on day one. That along with undercoating and paint protector was all done before it left the showroom floor. Aside from the lower control arms and a very few small bits in the suspension, there is absolutely no rust on the undercarriage or in the engine bay. But I think your right, if I pull the engine this winter, I'll break out the spray9 and toothbrush and have at it. I thought you would have noticed my new signature by now...I like white....LOLGro Harlem wrote:ur mx is white?
You know I tried to copy your CAI also. Nothing wrong with following the path of those that went before me.
