Door Inserts
Door Inserts
Im sure this topic has been posted before, so I apologize in advance. Im sure that anyone with a teal mx-3 knows that in 1992 the interior cloth in the doors looks like s---, and many people have changed it. What a great idea. I tried removing the fabric and replacing it with other materials, but im truly not that skilled in that department, as per its an extremely hard job, and most often people hire someone to do that. But, i remember seeing someone who had removed the door fabric, and did some type of spray painting that looked really nice. If anyone has any information on working the door panel fabric area to where it can be spray painted, or a link to that person who spayed theirs, please let me know. Thank you
- azazel95
Well I haven't done this nor does my mx3 even have fabric on the door panel ('95 rs) but I would assume that after ripping off the fabric, you would need to remove any glue/adhesive and sand down the surface flat and clean it well. Then use masking/painter's tape to cover up anywhere around the area you don't want to get paint on and find a high quality spray paint and go at it. This is just off the top of my head and if it sounds right I would assume it works.
If you have already removed the fabric you should be able to see if only painting it would look right. Depending on how the fabric was attatched, you may need to do slight mods on the door panel to make everything flush and even.
My 2 cents.
My 2 cents.
- Hoodzy
i'd suggest looking on cardomain
i've seen quite a few with that done
1995 Creek Mica Blue GS
- azazel95
You will have to look at that and judge for yourself. You're going to want it to look even and nice, so with the fabric removed is the surface flat? Or does it have ridges or something where the fabric attatched?MHMX-3 wrote:would taking off the fabric, sanding, and spray painting suffice? if not, where would i purchase fiber glass resin, and how expensive is it?
As for buying fiberglass resin I have no idea...custom car shop maybe
I took off my fabric already...there is a vinyl like padding under the fabric, and under that, the cardboard-like backing of the panel. You could paint the panels with the fabric off, and with a bunch of layers of paint you could probably get a smooth finish, but my experience with painting vinyl or rubber-like materials like that is that the paint will eventually rub off and you'll have to re-paint it.
You can buy fiberglass resin or any other hardener compound at Home Depot. Just remove the fabric, paint a few layers of resin on, and when it hardens sand and paint. This should give you the most smooth and permanent finish, in my opinion.
- neutral
Re: Door Inserts
Here ya go. http://www.cardomain.com/ride/360367 It's GregoryChristian's MX-3. That's his s/n here so you could maybe PM him w/Q's. Also try a BB search for posts about other's experience with this.MHMX-3 wrote:...If anyone has any information on working the door panel fabric area to where it can be spray painted, or a link to that person who spayed theirs, please let me know. Thank you
You're right too, recovering w/fabric is a major PITA. Inserts have compound concave shaped curves that are a nightmare to get pro looking results w/recovering. Someone recently posted here that they asked a friend, who does auto interior work, about degree of recovering difficulty and the guy told him the MX-3 was in the top few cars that his shop wouldn't take on because the pita factor. G'luck with the glass and paint tho. Gregory's came out really nice.
