How much do rims affect my spedo on my V6?
I am taking the car to get the tranny rebuild
I got 18 inch rims in the back and the 14inch stock wheels in the front (I think its 15inch stock wheels, dont remember)
Anyway, I know bigger rims affect the speedometer but by how much is it going to affect my MX3?
by the way, yes I do got two more 18inch rims for the front, its just the tires are dead, need to replace
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Give us the size of the TIRES going on the front, and we can give you an exact figure... it doesnt matter if you had 35" mudgrips on the rear, that wouldnt' throw off the speedo a hair... .well, except for the fact that you'd be riding on the front bumper instead of the tires..
Speedo error is calculated by comparing the circumference of the original equipment tire to the circumference of the new tire.
Daniel
Daniel
--Maybe the Hippopotamus was just a really cool Apotamus.--
Re: How much do rims affect my spedo on my V6?
Juans_93_MX3 wrote:I am taking the car to get the tranny rebuild
When this thing hits 88mph, you're gonna see some serious TIHS...!
No, its just that the front tires need to be replacedJ0HN_R1 wrote:Juans_93_MX3 wrote:I am taking the car to get the tranny rebuild
by the way, yes I do got two more 18inch rims for the front, its just the tires are dead, need to replace1st, the wheels in the front are gonna be smaller, and the speedo takes its reading from the tranny anyway...
2nd, WTF are you doin with 18's in the back & 14's in the front...? Going for the RWD "muscle-car" look...? Please tell us they're different style rims cause one/both of the 18's are being replaced...?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
ok, so you are in a GS..
so that means your front tire are 15" rims, with either 205/55/R15 or 195/60/R15 tires on them. That is normal.
Now if you go to 17s, you will need to go to around a 205/40/R17 (depending on width of tire you want. But that is a difference of 1.256" around the tire. So, a difference of -1.5% on your speedo. ((new circumference-old circumference/old circumference) * 100).
I used http://www.s-series.org/htm/calc/tiresizeconv.htm to convert the diameter from the tire sizes. and the old stanby of PiD for the circumference.
Rear tires do not matter as the front ones are the ones that are the drive tires, and hense where the speed is coming from. The rear tires, if larger, will simply spin slower, if small, will spin faster.
our friends over at miata.net have done most of the leg work for us....
their garage section has many handly tools such as this one:
http://www.miata.net/garage/tirecalc.html
That is a cool little tool.D323 wrote:our friends over at miata.net have done most of the leg work for us....
Didn't know i was going 2k slower than the gauge. I thought i was a bit faster.
