IHI turbo?
Posted: June 25th, 2005, 6:46 pm
by ncmx3
Do you guys think an IHI VI 34 would be good for the klze? I want to run up to 10psi on the turbo.
Posted: June 26th, 2005, 10:02 pm
by BuGS
VI?? Do you mean VF? If you do it is a great turbo. Not to make you seem like you don't know anything but are you putting different pistons in the KL-ZE? Or are you doing water injection and running huge injectors?
Stock the Engine will blow with that much PSI. The Stock Compression is really high.
