VI?? Do you mean VF? If you do it is a great turbo. Not to make you seem like you don't know anything but are you putting different pistons in the KL-ZE? Or are you doing water injection and running huge injectors?
Stock the Engine will blow with that much PSI. The Stock Compression is really high.
