Help: Leak from oil Pan
I cnat tell where its leaking from but it dripping down the side of the oil pan is it the gasket and if it is what do i have to do thanx guys pm me
clean off the oil with brake cleaner and well run the vehicle while its in the air and look for a leak it might be ur oil sending unit thats leaking cuz mine was and it was puking oil all over so check that and if thats now it look at where the oil is comming from and that will help you out the most... i know it will take a while but it works trust me and it ll save u alot of headaches... hope that helps u out
