For the longest time i thought all tiny mazda motors did this. When I let the rmps drop, or idle, my car makes a pretty loud whine. I've only ever heard other mazdas do it, and they all had the tiny little motors. But from what i've been reading some people dont have that whine.
Does anyone know how to get rid of it? Or any tips and tricks to making the engine not so loud and annoying?
Thanks
Loud engine...
- happyclown
Loud engine...
1993 RS Teal
i get a little wine under full throttle kinda sounds a bit like a supercharger not complaining thou easies way to quite down your engine is get a touring style muffler you know the ones for minivans and such that will keep your exhaust note down a fare bit also keep your stock air box just a cone filter will make it scream (a good sounding scream don't get me wrong) other than that you can get the under hood dynamat it applys to your underside of hood just like as if were a door panel
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
- Tunes67
Only whining I hear from my car is usually from my passengers Ok bad joke.. Anyway..
Can you tell where the whine is originating from? Belts? Or is it something you are hearing from your speakers?
Tunes67
Tunes67
- happyclown
my thought was something like the water pump, but then mine went bad and i had that and the timing belt replace... its not that....
its not a 'cool' noise not the whine of the engine pulling air into the intake, and not the vroom out the exaust... its just stuff from the engine....
My best guess is the alt... a while ago i had to tighten my belts cause one was squealing (not this noise) and i tightened the looser of the belts, but it was the wrong one. Then i tightened the alt belt (which was already really tight) and it stopped slipping. so...
It could be that my alt is seasing up and its really hard to spin it. But would that really cause a whine noise I dont wanna buy a new one if it wount really help anything...
1993 RS Teal
