listen here i got a problem with my 1993 mazda mx-3 4cyl
ok when im driving along my car will be driving like it was brand new then out of the blue it bogs down somtimes worse then others ive replaced fuel pressure reg feul pump spark plugs wires radiator water pump ignition battery and terminals iwas thinking it was either the comp or the injectors please help me if youve had a similar problem or just know what it is please!!!!!!!!!!!!!!!!!!!!!!!!
i need help!!!!!!!!!!!!!!
- Tunes67
Is your car a ATX or MTX? When it bogs down.. have you tried shifting into nuetral or pushing the clutch in (depending on what trans you have). If you do and the car dies.. I have seen a reference indicating that is not a uncommon occurrance with a failing distributor. Have you tried pulling error codes from your ECU to see what is there? Have you run any fuel injector cleaner through your fuel system? If not try running a can of Seafoam through on your next couple of tanks of gas.
Tunes67
Tunes67
jimishadow
